Why Ovals and not circles
I’ve been using the adaptive layer hight function on 99% of my prints
I’ve found that for overhangs and holes printing vertically reducing my layer hight to .08mm (using a standard. 4mm nozzle) from about midway up the hole to the top overhang of the hole prints it clean and round
For top surface holes (horizontal looking from the top down) I use the same reduction in layer hight for about 4 or 5 layers at the bottom and at the top
Going from a .2mm layer hight to a .08mm layer hight will highlight the jump in layerhights visually unless you slide the curser up while holding the left mouse button and drag up while adjusting so the layer hight shift is more gradual
On the very bottom layer or if the hole starts at the base of the print I won’t shift the layer hight until the first 2 bottom layers are finished at the full target layer hight
This method isn’t perfect but if found for fitting parts together it makes the 2 parts fit nicely together and looks better than any other adjustment I’ve tried
I guess it’s sort of a workaround but it comes at a cost of time
I would suggest a simple file with holes both on the sides and the top
Lots of times I’ll just scale a simple model wayyyyy down and bang out quick test prints before starting a full size one with similar challenges
An XYZ cube, Benchy, or any of the caliberation test prints only gets me some of the adjustments dialed
Size, speed, color and layer hight are all factors depending on if they’re geometric shapes or organic shapes
Round holes in a round object are far different settings for me than flat surfaces with holes, 2 completely different challenges and settings regarding the minimum layer hight and speed in particular
Remember, variable layer hight is your friend but if you do it wrong it can be your worst enemy
Thank god its easily adjusted, reset and very finite in it’s adjustments
Hey Jrock another great reminder for us to use with holes and I do the same thing test out some small parts before the big part or cut the model up to test a areas that might be a problem and find out what works the best takes time but cheap insurance.
:v:
Had a similar issue when printing 2.4 parts in KVP ABS.
What solved my issue was adjusting the Jerk settings and cleaning the carbon rods every .5 kg of abs.
I’ve been forgetting to use it! Thanks for the reminder. I just Bookmarked this, it’s a great take on dialing in the hole / ovals and a bunch of other issues.
:rofl:
Like some other tools as well. A hammer isn’t always the right tool.
Dynamite however … :stuck_out_tongue_winking_eye:
Yeah, this. I love they just added " Support sinking and only slice model part above hot bed" to Studio 1.6. Going to DL it today and take it for a spin.
Ignore this. Posted in error.
All,
I have a case open with Bambu on this that is about a month old now, but they are working on it. If you are experiencing ovals when printing horizontal holes in vertical surfaces, I urge you to put in a support case. You can cross reference to my case if you like (it is currently escalated to the Engineering team) - my case number is US230409716001.
I have tried all of the recommendations in this thread and others. I have tried several different materials, print speeds, wall types - I even disabled z-hop thinking that perhaps it the nozzle was coming down a little too far after the hop.
I have submitted pictures to Bambu showing caliper measurements that depict the hole about 10% wider than tall - but the overall print is accurate. I have high hopes they can figure out what is causing it since it is only happening to a small minority of owners.
Mark
Jonheff - did you get resolution yet? I still have an open case with Bambu (US230409716001) but no fixes just yet.
Mark
No I have not resolved it as yet. Was working on my car. Then went back to the voron 2.4 Just to let you know. I have been printing with PLA. With no problems. But I only printing things that do not require, horizontal holes. Like you say. The printer is printing fine. The layers and dimensions seem to be ok. Will look into getting a support ticket. Just a bit busy at the moment. With work.
Just my quick two cents on this topic… I noticed that OP is using black filament. In my experience very dark filaments do not work well with flow calibration, resulting in rounded corners. These rounded corners may be the cause of the oval holes. When I want to print with dark filaments, I first do a small print of a test block in a white or light filament and flow calibration on. Then I switch to the dark filament and skip the flow calibration. The X1 then uses the flow calibration of the light filament with the dark filament, giving me way better results.
I’m having the same exact problem of oval holes in my prints. Large holes, small holes, horizontal, vertical, it doesn’t matter. I’ve tried different filaments and settings to no avail. Eagerly awaiting to see if they get it fixed with you @msteele999.
iDrift,
I highly recommend opening a case with Bambu and referencing my support case and this Forum thread: Support case #: US230409716001
We are getting more and more reports of this behavior so the more examples we can provide Bambu, the higher the likelihood of them being able to resolve it.
The belt tensioning procedure does not explain where in the back. Left, right, center?
It made no difference to my second attempt at this bambulab filament winder.
How come the printer cannot diagnose this issue?
–>> FOR THOSE OF YOU EXPERIENCING THIS ISSUE <<–
I have a long standing support case open and a support engineer that sincerely wants to get this resolved. He is asking if I can get the case numbers and / or serial numbers of printers that are experiencing this problem so they can check them against their records to see if there is some correlation.
If you have this issue, please open a support case and then please provide me with your printer serial number and your case number if you have it. Even if you don’t open a case, please send me your printer serial number and I will add it to the list.
Best regards,
Mark
Is there a file to test it reliable?
I’ve been using this Voron heatset test stl:
Did you receive the image I sent you of the serial numbers. Also have you had much response. With people sending you the info?
I printed it with you settings. The horizontal holes are fine, but not the vertical. And the heptagon is on the lower part smaller - diff. is ~1mm
Am I wrong, or is it a problem with Orca?
There are 24 layer who should build the 5mm hole. But 24x0.2 is 4.8… this hole can NEVER be round!
If you choose 0.08 layher high, you habe 63 layers. 63x0.08 = 5.04mm
With 0.2mm layer gight, there should be another or two additional layers before the “large” bridge.
Hmmm… maybe thin or thicken first layer, or change the position of the hole by .01mm so that 25 layers can be used?
Do any slicers automatically vary the layer height to deal with this sort of situation?
S3D has 25 Layer → 25x0.2 = 5mm
I just found this thread, I have been having the same issues on a new bamboo p1p i bought a few months ago. Did you find a resolution to this?
