I’m using Orca Slicer and the X1C printer displays the following warning on every print.
“Warning - The current nozzle setting does not match the slicing file….”
I do not get this warning when I slice with the Bambu slicer.
Anybody else seeing this?
I only see that when the printer nozzle differs from the nozzle chosen for the project.
This warning message started with the last firmware update.
Same problem here. Since Fw update from 01.10.00.00 to 01.11.02.00 today, I have the same message on the printer. Nozzle settings are definitely the same on the printer terminal and Orca slicer. Doing a complete calibration again did not solve it.
I cannot test with Bambu Studio, since on uploading the print, I get a timeout error with Bambu Cloud. Even the printer is in lan mode and developer.
'“Restore factory settings” from the printer display often corrects strange errors after a firmware update.
See here, switching back to 1.10 is the solution.
