The white is Pla Basic and gray is nardo gray matte. No under extrusion in any place, and overall very smooth.
Since yesterday I have reset back the Z offset to 0 as I had very hard times to remove the parts from the bed. So I have played a lot with the process and filament profiles. And used simple primitives like resized cube. Then ran some trials until get good surfaces and pa-s. Basically it required more flow rate and more pa, then what is shown from the Bambu calibration patches. + bring the speed 20-30%, and also moded some other parameters in the process like infill/wall overlap from 15% to 10-12%. And also infill direction from 45 to 0/90.
It seems like variation between the colors and types of PLA is very big, or maybe x2d is very sensitive to small changes and need very precise setting.
There is a glue on the plate, and it was hard to remove previous print. This one seems to be failed from the bottom to the top + stringing, which I did not saw on the previous print. But this time I have the aux with Bambus’s dark brown matte, which seems to be really hard for the X2D.
What was the exact reason they replaced your printer? I bought 2 X2D’s for more production machines to add to my fleet. I am experiencing several issues including 1st layer issues. To the tune I have buyers remorse. I would rather have machines that work. These two attention deficit disorder machines I have are diverting my precious time away from production activities which is bad for business. so far all calibrations so far diagnosis of the various issues are not changing much. Prob will be submitting a support ticket soon. Feel free to DM me if needed. Thanks for your input.
After a couple months of testing, I simply gave up. Run out of ideas, time and patience to do another set of tests. For now, printer is standing idle with around 600h of work, from with more than half was spent on testing. I managed to improve outer walls uniformity but top layer under-extrusion issue is still persistent. Also, new issues arrived, in form of layer shifts, especially on support, resulting in couple failed prints. I always try to weigh my words but for me it’s worst Bambu printer to date. It feels rushed, both hardware and software side. Most important, it lacks repeatability and this was always - at least for me - the greatest advantage of this brand.
Yeah, these are wise words, but at the same time, words that will fail to cut through the noise, sadly. Looking at Facebook groups or even this forum, for most of the users issues are not existent if they don’t experience them. And sure, it makes sense in some way but still, there is a noticeable lack of a broad perspective on this issue. What’s the worst, there is a fair amount of aggression in how users respond to the problems of others - often resorting to the classic tactic of implying that the user is at fault, or even suggesting that a competitor is behind the issue. Then again, that tends to be the case in practically any discussion about hardware or similar topics.
I have some spare time in coming weeks so I will do a bit more of testing on new firmware and then sell the unit. Due to that, i resigned from buying P3C and went for Snapmaker U1. After coupe days of work - no issues at all. Great first layer, uniform top layers and outer walls. And even if this model has its drawbacks, it is repeatable.
