You can find OrcaSlicer work on GitHub. LixNix (PR# 13782) shows the per-feature nozzle/filament assignment work to support multi-size nozzle printing (for the same part). I’m recommending a different approach:
Mixed Nozzle Diameters: A Fine-First, Band-Based Model
Prepared for consideration by the Bambu Lab engineering team
Note up front
Bambu’s own FAQ already states that mixed nozzle diameters are planned: “Currently, the firmware supports mixed flow-rate printing… but does not yet support mixing different nozzle sizes during printing. If this feature is added in the future, we will provide details through a software update.” This document isn’t a request that the feature exist — that’s already committed to. It’s a specific mechanism for how to do it correctly, offered in case it’s useful input while the design is still open. The mechanism itself only requires two-or-more-nozzle hardware — it applies to H2D/X2D’s independent-nozzle setup as much as to H2C’s Vortek rack — though as noted below, Vortek is particularly well-suited to it. If the internal design already covers this ground, most of what follows will be familiar; if any of it isn’t, it may save some iteration.
What hardware this needs, and where Vortek has a specific edge
The mechanism above needs only two things from the hardware: some way to bring more than one nozzle diameter to bear within a single job, and enough control over swap/Z-motion timing to enforce the fine-first, flush-boundary ordering. That’s satisfied by any of Bambu’s multi-nozzle platforms — H2D and X2D’s independently-mounted dual nozzles work by the same logic as Vortek’s hotend-swap rack, since the access constraint driving fine-first ordering (a nozzle’s widening cone can’t reach the base of an already-printed taller wall) applies identically regardless of how the second nozzle got into position.
Where Vortek specifically pulls ahead is color. Because each hotend stays pinned to one filament/diameter identity with no purge on swap, Vortek is the only current Bambu platform where diameter-splitting a color doesn’t reintroduce the flushing the swap system exists to avoid — H2D/X2D’s fixed dual-nozzle setup doesn’t have that slot flexibility, so multi-color plus diameter-splitting together is a Vortek-specific strength, covered in the color section below. For single-color or few-color jobs, any of the multi-nozzle platforms should support this model equally well.
There’s also a broader structural point worth naming: this is buildable correctly at the firmware/motion-planning level on any of Bambu’s own hardware, in a way no third-party slicer working around opaque firmware from outside — including OrcaSlicer’s current in-progress community effort — can fully replicate, since visibility into swap timing and Z-motion sequencing isn’t available to them.
The core reframe
Treat the entire print as defined at the finer of whatever two nozzle diameters are paired for a given job — that’s ground truth for quality in that pairing. (“Fine” and “coarse” here are relative roles, not fixed diameters: a 0.4/0.8 pairing works by the same logic as a 0.2/0.6 pairing, with 0.4 playing the fine role in the first case. The rest of this document uses 0.2mm fine / 0.6–0.8mm coarse as a concrete illustration, since it’s the widest and most demanding spread available across Bambu’s own nozzle lineup, but the mechanism is diameter-agnostic and hardware-agnostic.) Anywhere a region is provably identical at the fine nozzle’s resolution to what the coarse nozzle’s bead would produce, substitute the coarser nozzle there for speed. Everywhere that substitution isn’t provably safe, stay fine. The coarse nozzle is strictly a speed optimization over a description that never changes — there’s no reconciliation between two different things, because the coarse region is a faithful shortcut for the fine region, not a different thing meeting it.
Fine Skin: the user-facing surface
Whatever the underlying mechanism, it doesn’t need to be user-configured directly. Model the front end the way Bambu Studio already models Fuzzy Skin: a named treatment (“Fine Skin”), applicable globally by rule (all outer walls, all features under N mm) or painted onto specific regions, with paint always available as an override. The user expresses intent — spend additional fidelity here — and the slicer/firmware decides how to deliver it given the hardware. Everything below this line is what happens underneath that request; none of it needs its own UI.
Layer groups and the flush-only-at-boundary rule
Define a layer group: a Z-band reachable both by N sublayers at the pairing’s fine diameter and by exactly one layer at the pairing’s coarse diameter, with the group height solved per-region as a mutually-reachable value (layer height is already continuously variable via squish/flow-rate, not fixed to nozzle diameter).
The rule: fine and coarse may only meet at the top of a group, never mid-band.
This is an access constraint, not a travel constraint, which is the important distinction — it’s not solvable with a Z-hop before a travel move, the way ordinary stringing-avoidance is. A nozzle is a cone that widens with height, so depositing material immediately adjacent to an already-printed tall wall means the cone’s flank has to occupy space the wall already fills, right at the point of deposition. If coarse prints first, there’s a wedge of geometrically unreachable space at the base of every tall coarse feature — no travel maneuver reaches it, because the obstruction is at the destination, not in the flight path. Fine must print first within a group for this reason: it’s placing material on a clean flat surface with nothing tall nearby yet, so there’s no access problem at all. Coarse then fills the remainder, inset from the fine feature by its own clearance radius, which the fine geometry already accommodates.
This rule caps a group at two nozzle sizes — a third size introduced mid-band would need to meet the fine stack at a non-boundary Z, reopening the access problem. Adjacent groups (different Z, or different XY regions at the same Z) are unconstrained and can each independently use a different coarse partner, so the full 0.2–0.8mm range remains available across a job — just never more than two sizes within one group.
Where coarse is allowed to substitute
Two tests per candidate region, both fail-safe toward fine:
Stability: are the region’s contours congruent across all N fine sublayers in the group? A region that steps in and out mid-group fails automatically and stays fine.
Clearance: once inset by the coarse bead’s radius, is the remaining region wide enough for the coarse nozzle to deposit?
Because coarse only wins where both tests pass, visible or complex geometry is guaranteed to stay at fine resolution — the optimization can only trade fill-speed for fill-speed in verified-simple bulk, never surface quality for speed.
Why a shared layer height isn’t a viable long-term target
This is likely the single most important point in this document, and it’s a hard physical constraint, not a design preference.
Printable layer height for FDM nozzles runs roughly 20–80% of nozzle diameter. That gives a printable range per nozzle:
Nozzle
Range
0.2mm
0.04–0.16mm
0.4mm
0.08–0.32mm
0.6mm
0.12–0.48mm
0.8mm
0.16–0.64mm
The pairings below use 0.2mm as the fine reference since it’s the most demanding case, but the same intersection logic applies to any pairing from the table — a 0.4/0.8 pairing, for instance, intersects at 0.16–0.32mm, a real and workable range for that pair, by the identical math.
A shared-layer-height model — one global Z-step across all nozzles in a job — is constrained to the intersection of whichever ranges are in play, not either nozzle’s own range:
0.2 + 0.4: intersection 0.08–0.16mm. Real overlap; most of the fine nozzle’s practical range survives, and this pairing works reasonably well shared.
0.2 + 0.6: intersection narrows to 0.12–0.16mm. Most of the fine nozzle’s useful range is gone.
0.2 + 0.8: intersection is a single point, 0.16mm — not a usable range at all. Under shared layer height, this pairing is functionally unprintable together.
That last row matters for any hardware capable of mounting a 0.2mm and 0.8mm nozzle in the same job — H2D and X2D’s independent dual nozzles included, not just Vortek’s rack. It’s worth flagging for Vortek specifically as well, since 0.2–0.8mm is the full advertised range of the induction hotend lineup: a mixed-nozzle feature that only works cleanly for adjacent diameter pairs doesn’t deliver on the actual spread that lineup offers, on whichever platform it’s mounted.
There’s a second cost even where the intersection is nonempty: squishing a coarse nozzle toward the bottom of its range to stay compatible with a fine nozzle doesn’t just risk the flow-inconsistency issues that show up near the low end of any nozzle’s range — it also caps volumetric throughput (cross-section ≈ line width × layer height), which is the actual lever multi-nozzle hardware exists to pull. A 0.6mm nozzle squished to 0.16mm layers is running at roughly a third of its own natural throughput ceiling — present and technically printable, but not delivering the speed the larger nozzle was chosen for. Full utilization of a coarse nozzle’s speed advantage requires both a wide bead and a layer height sized to that nozzle’s own natural range — which per-group Z-reconciliation provides and a single shared Z-step cannot.
Put simply: if time-of-print doesn’t matter, a single 0.2mm nozzle everywhere already gives maximum resolution — that’s the null hypothesis multi-nozzle hardware exists to beat. A mixed-nozzle implementation that can’t let the coarse nozzle run near its own natural layer height isn’t actually delivering the reason someone would want multi-nozzle hardware in the first place; it’s delivering a modest quality/strength benefit at close to single-nozzle print time.
Where color enters: Vortek slot budget
Vortek gives fast, no-flush color/material swaps because each hotend stays pinned to one filament identity for the job. If a color is allowed to split across fine and coarse diameters, its true identity becomes (color, diameter), needing two dedicated slots rather than one.
On H2C specifically: 6 automatic Vortek identities (1 mounted + 5 racked, per Bambu’s own published spec) plus 1 fixed manual hotend on the left — 7 total, not independent from the diameter-splitting decision. Every color that gets diameter-split draws down the same finite pool that color-swap speed depends on; pushed too far, it reintroduces the flushing Vortek exists to eliminate.
Where color and diameter decouple entirely: if every visible surface color is opaque enough to fully hide whatever’s beneath it, structure color doesn’t need to match surface color at all — one shared, fast, universal structural color can serve every visible color in the job, diameter-split freely, at a cost of one slot total regardless of color count.
Where they don’t: a translucent or light surface color needs its coarse fill to color-match to avoid show-through, which costs a full second slot per such color. This is the one place in the whole model that isn’t geometric — it requires an empirical fact (minimum hide-shell thickness per material/color pair) that nothing in current slicer or firmware logic models.
Suggested default, given that: rather than modeling opacity, a fixed, safe allocation — 3 colors × 2 diameters = 6 identities, matching the 6-slot automatic Vortek pool, every color always getting its own dedicated coarse variant — is correct regardless of material opacity, at the cost of leaving opaque-job shared-structure savings on the table. The 7th, fixed-left identity sits naturally outside that allocation as a place for a single always-available color that doesn’t diameter-split. An advanced/override mode, letting a user manually declare which colors are safe to share structure, can recover the opaque-job savings for anyone willing to make that call — same rule-plus-override pattern as Fine Skin itself.
Relationship to existing slicer-side work
OrcaSlicer has an in-progress community PR (LixNix, #13782) extending per-feature nozzle/filament assignment (walls vs. infill vs. top-bottom) to Bambu’s multi-nozzle machines, and there’s an open community discussion (#10175) from an IDEX printer owner independently identifying shared layer height as “the most significant drawback” of multi-nozzle printing in practice — corroboration that this gap is real-world, not theoretical. That work is valuable and solves a real, adjacent problem (particularly for close-diameter pairs and material-property differentiation, e.g. rigid vs. foamed material in one part) — it’s a different, narrower mechanism than the one above, not a competing solution to the same problem, and nothing about implementing the band model above would conflict with it.
Why this matters commercially, not just technically
0.4mm was never an optimum — it was a forced compromise, and it’s worth being precise about why. 0.2mm is too slow and incompatible with a range of filled/abrasive filaments. 0.6mm and 0.8mm show visible layer lines and lose small features often enough to be disqualifying for anything cosmetic or customer-facing. 0.4mm isn’t the best point on a curve — it’s the only single value that avoids both failure modes at once, because a print could only ever have one nozzle. The moment that constraint is gone, there’s no reason for one value to survive both failure modes simultaneously: visible surfaces get the resolution that avoids “looks bad,” hidden bulk gets the diameter that avoids “too slow.” The entire installed base of 0.4mm-default usage is evidence of a workaround for a hardware limitation, not evidence of a preference for 0.4mm itself.
The strongest market case isn’t speedup on existing jobs — it’s jobs currently declined outright. A straightforward 2-4x speed argument on already-quoted work is a real, useful case (more competitive bids, better margins on multi-color/fine-detail jobs a farm already serves), but it’s competing for revenue that already exists in the market. The larger opportunity is upstream of that: requests a print farm currently can’t accept at any reasonable price, so they’re never quoted at all. The clearest example is also the technical ceiling case for this whole model — a part needing genuinely fine (down to ~0.04mm) surface finish on visible geometry, with real structural bulk underneath. Today that request gets declined for FDM and routed to resin (different process, different size and material constraints, different cost structure) or accepted at an honest, embarrassing quote reflecting printing the entire part at 0.04mm. Under a shared-layer-height model this pairing isn’t just slow, it’s mathematically unprintable together — the 0.2mm and 0.8mm printable ranges (0.04–0.16mm and 0.16–0.64mm respectively) share only a single boundary point, not a usable range. Per-tool layer height is the only architecture that can accept this class of job at all, not just accept it faster. That’s a claim about expanding what a print farm can say yes to, not about doing the existing catalog more efficiently — a materially different, and generally more persuasive, kind of business case.
Automotive replacement parts are a concrete, present-day example of this exact shape of demand. A functional under-hood bracket in CF-nylon where nobody will ever see it is already well served by a single coarse nozzle today — that’s not a new opportunity. The interesting case is a visible replacement part (trim, housing, anything replacing a smooth OEM surface) that also needs real structural integrity and, often, functional mating-surface tolerance — a connector shroud, a gasket seat, a bearing bore — where visible layer lines aren’t just unsightly, they can mean a leak path or a fit problem. That’s a job with genuine hidden bulk and a non-cosmetic reason to demand fine resolution on the skin, and stair-stepping on the curved surfaces common to this category is precisely where fine resolution has the most visible leverage. This is a job type that exists today, gets either quoted high or declined, and would move cleanly into “yes” territory under this model.
Every mechanism here — bands, flush-boundary ordering, stability/clearance tests, swap scheduling, color/diameter slot allocation — is either a bounded extension of something slicers already do elsewhere, or a direct consequence of nozzle physics (squish range, cone geometry, volumetric flow) that doesn’t require new material science to account for. The one genuinely new input — opacity-driven structure sharing — is deliberately kept out of automated inference and left to a safe default plus an explicit user choice. Given that Bambu already controls swap and Z-motion timing at the firmware level across its multi-nozzle hardware, this is buildable correctly in a way no third-party slicer can currently match from outside that hardware.
