In some cases gap filling is not desirable. Please add checkbox to disable gap filling entirely.
Yes, please! A setting for disabling gap filling!
I am currently working on a project with thin walls on a lamp, and I cannot get rid of gap filling. It increases print time massively, and ruins the finishing, as well as the translucency. The only way for me to get rid of it, is to fiddle with bottom and top layer settings (putting them at 0), which is not ideal for the model for obvious reasons.
Yes, please let us disable gap fill!
Also, adopting the “minimum gap fill line width” and “minimum gap fill area” from Superslicer would be very helpful. These let you allow gap fill, but selectively remove areas which are too small or narrow to worry about.
+1
I hope we can get an option to disable gap infill soon.
+1 vote from me. This is a must have in some prints (e.g. TPU)
You should try “Arachne” mode for “Wall Mode” this nearly completely remove gaps and so gap infill by using variable wall thickness
Thank you. I will try this.
I had exactly the same issue and this solved it. Thank you so much!
I’m still new to 3D printing, and am trying to understand this gap filling issue. Can’t gaps be controlled with this setting?
Orca has a “filter out tiny gaps” setting, sounds like what you guys are looking for?
changing this number does not do what you think it does. It deletes thin slots in STL files that are below this threshold. Not how big of a gcode wall gap it tries to fill with “Gap infill” paths.
Thank you for pointing out this setting. I had glossed over it as something else. This is the best solution so far until bambu gets around to implementing it. For others looking for a solution. It is under Strength>Infill>“Filter out tiny gaps”. a value of 1 cut out some really really small fills. a value of 2 cut out the ones giving me trouble but left all of the reasonable paths that would need filling.
Justy noticed this thread, just set the Gap infill (Speed tab) to 0. it will stop the silly gap fill. I hope they just add a setting /threshold to fill it proparly…
OMG, thank you! I almost tried that but figured it would just do like line widths where 0 = some default.
THIS IS THE ANSWER! BUMP it up!
Thanks just solved my problem!
When I set the gap infill speed to 0 it still tries to print the gap infill. However the speed seems to adjust (up to crazy values) in order to compensate for the flow rate change?
This early answer may be a better option because the lines are completely filled without the need for gap filling. It adjusts the thickness of the line as needed. It is in Quality->Wall generator
Just opened a request on Github: Option to disable gap infill
It’s a workaround, not a solution. Arachne help to solve one problem and creates others. I for example can not use Arachne, it actually creates gaps in my case.
