AMS 2 Pro Feed Issue (also)
My problem appears to be identical to AMS 2 Pro Feed Issue which was posted 6 months ago and was not resolved. In my case:
AMS2 Pro atop P1S printer. Referring to HMS_0700-2000-0002-0012: AMS A Slot 1 feeder motor overloaded, unable to rotate the spool. | Bambu Lab Wiki , the filament appears to get as far as the internal hub unit, but then the small stepper motor at the front of the unit makes repeated attempts to push the filament further before giving up.
If I press the button on the internal hub unit, I can manually feed the filament past the internal hub unit and out the back of the AMS2, so I don’t think there’s a blockage. And when I ask the system to unload the filament, it can successfully pull it back.
And I’ve verified that this happens for multiple slots (I tested slots 1, 2, and 3).
The Wiki troubleshooting guide says:
If the filament cannot pass through the internal hub unit normally, please disassemble the internal hub unit to check if the sensor’s magnet is working correctly. If the magnet does not rebound properly, the internal hub unit needs to be replaced.
So I’m hoping that I don’t need to disassemble the internal hub unit and that there are other things I should check first. But if not, can you point me to instructions on how to disassemble the internal hub unit? And what does it mean to “check if the sensor’s magnet is working correctly” – how do I test for that?
Update: Solved (but I don’t know why). Following several instructional YouTube tutorials, I disassembled the internal feed hub, checked for any internal obstructions (none), checked the magnets (working properly), checked that the tachometer sensor rotated when filament was fed through it (check), and reassembled the unit without making any particular changes.
Result: it now properly loads and feeds filament. The universe works in strange and wonderful way.
