Hello, I am trying to print a model that I have painted two separate colors with using my AMS. Whenever I go to print it, I dont have the option to select two different colors, rather I have only one color selection.
(I cannot embed links or images) i.imgur.com/JZIdQGe.png i.imgur.com/wmwfZid.png
I believe this is a bug as this has worked for me before. The biggest difference being that the project is multiple plates and has multiple components, but the different colors should still show.
Ikraus, thanks for your help. That checkbox was not visible in v01.09 but now that I installed 10 again it is there. Iāll play with the settings to get similar number of triangles that 09 produced, wish I made a note of them originally, I will now. Thanks again.
Problem: Using fill tool on a curved surface causes colour to bleed outside the required area on inner layers, spoiling the appearance of the final print Studio Version: v01.10.02.76 Platform: Windows 11 Steps to reproduce:
Load model with an indented curved top surface. Use Fill Tool to apply filament of different colour to the indent.
Other information:
The top layer is filled correctly. The inner layers have colour bleed outside the required area. The extra plastic affects the final print when the plastic is not completely opaque. The model shown below is a switch cap of approx. 15mm sq, the indent of the āCā is 0.05mm.
If you want to pin a collection, the values in the new window of the collections you have are swapped.
I hope I have somehow made myself clear, sorry for that.
Hi, i think i found a bug when you combine Infill Layers.
if you print a fast moving, combined infill it ignores the Max flow of the filament settings.
I have high flow nozzle with 45mm/s flow but if i use a 400mm infill speed and a combined Infill Layer the max flow gets ignored and i have a flow of roughly 75mm/s which is the extruder max cap of my P1S.
It should be possible to limit the Speed so that the Max Flow of the Filament setting is achived.
Hi i just came from vacation and my bambu studio stoped working, if i chose a object ,try to slice or do anything in general it closes on its own.
Things that i have already tried: reinstall, install beta version, limit number of cores, update all the drivers, update java, installed orca to check and it works normal, i dont know what to do anymore it was working 2 weeks ago, the crash log i get is :
Exceptions:
Exception Code :c0000005 ACCESS_VIOLATION
Exception Flag :0x0 NumberParameters :2
Param 0 :0x0
Param 1 :0x4
Context :00000064275FCC40
ContextFlag : 0x10005f, EFlags: 0x10206
Fault address: 0xA3C1DB43 0x0:0x0
Problem: Bambu Studio starts on Mac OS but now window is displayed Studio Version: 1.10.2.76 (also tried 1.10.1.50) Platform: MacOS Steps to reproduce:
Around an hour ago I started Bambu Studio and it asked me to download some updates (not the app, just some profiles or stuff) I accepted and after this the following happens:
Open Bambu Studio
(when changed the version) the dialog for the Network-Plugin shows up, does its stuff and closes
Problem: Canāt log into the BambuStudio Mac app with authentication services (google, apple, facebook) nor system browser login. I get a DNS_PROBE_FINISHED_NXDOMAIN error. Studio version: V01.10.02.76 Plateform: macOS Sequoia 15.3.2
I donāt know if this should be considered a bug report or a feature request, but thereās a problem to fix in Bambu Studio. When someone downloads a 3MF sliced for a particular printer, and they select a different printer to print with, some slicer settings donāt persist. Particularly, the wall generator reverts to Classic if the profile uses Arachne. I have several uploaded profiles on MW that require Arachne to print correctly. Any setting that isnāt specific to a model of 3d printer should persist when a person selects a different printer. The whole point of uploaded profiles is to make it easier for people to print models successfully. I shouldnāt have to warn people that my model has to use Arachne.
One more bug to report. Iām not sure if this is still the case with the new update, but in the previous version, Iāve seen an artifact on a model when using Arachne, that goes away when using Classic generator. The model is a can holder, and I use fuzzy skin and random seam. If I use Arachne, it puts a vertical line up the far right side of the model that looks like a seam, but isnāt. If I rotate the model, the line moves to the far right side again, wherever that happens to be on the model.
