Gold textured PEI plate maintenance recommendations
7 months in, original plate, no physical damage, and adhesion is great. So here are my suggestions.
  1. Wait for the bed to cool below 30 deg C before removing objects. Removing with the plate hot stresses the coating as its SUPPOSED to have good adhesion when hot. Even BL mentions that the “instant release” is after the plate has cooled. Just removing it to let the metal cool down quicker is not enough, as the plastic will take more time to cool down.
  2. NEVER use the metal scraper they supply as it WILL eventually damage the coating. Save that for a smooth plate. You can get scrapers with nylon “blades” off amazon for dirt cheap. They have worked great for me so far.
  3. Just use soap and water to clean it with. If you can get the original Dawn dish soap from the store use that, as it’s the best thing I’ve found for getting all residue off. I noticed a big difference in the feel of the plate between Dawn and other soaps.
  4. Although you may not have printed on a section of the plate for a while, trying to do so after a number of prints can still have a part let go during the print. Why? Some of the plastic fumes inside the chamber on the core XY printers will collect on the plate every time you print. Eventually it can build up enough to affect adhesion.
  5. Only handle the plate with clean hands or gloves. Skin oils and anything else you may have on your fingers will rub off on the plate. I have oily skin, so I have to wash my hands or wear gloves every time I handle a plate.
  6. The plate guides on the back of the bed a marginal. ALWAYS use a fingernail or something else to makes sure the back corners of the plate are fully on the magnetic plate.
Yeah, I know, some people use alcohol, etc. But some people using these other cleaners have still had issues with adhesion. I haven’t.
Looking into 2 other options.
Using simple green instead of soap
Throwing a plate in the dishwasher
Going to be contacting Bambu Lab on these ideas, so stay tuned for the response.
I use glue stick on mine as mold release to prevent the plate from wearing out.
Here’s Bambu’s reply on using a dishwasher or Simple Green
"Yes, I have seen them cleaned in the dishwasher. I don’t think there should be a problem as they can withstand the heat easily.
The simple green cleaner should work. It states it is a degreaser. That is what you want. I cannot confirm the function 100% but it looks good to use.
Lots of customers use simple dawn dish soap and are happy with the result."
So, like I stated earlier, Dawn (original has the best grease cutting additives) is a great option. But if you want more heat to dissolve any coatings, the dishwasher is an option too. I’d pull it out and dry it by hand to prevent water spots though.
Will give the Simple Green a try and pass on the results. Degreasing and surface cleaning mixes vary from a 1:3 dilution to a 1:10 dilution. Will start with the 1:10 and increase if needed. Will give results in a couple of weeks.
Annnnd . . .
You are eventually going to have to clean the residue off the plate. So you still need to clean it w/o damaging it.
Right but i soak it in degreaser until it dissolves. No need to rub or scrape the plate
I am a newbie 3D printer and only had my carbon now 4 months but have 350 print hours. Love the PEI gold plate, as I hate the time it takes for glue stick application. I print a lot of small parts and test parts and started having spaghetti issues on the first layer “all of a sudden”. Was worried that the printer was broken, when I decided to simply flip the plate over, and WHAM, all the problems solved instantly. When I put another 350 hours on this side, I will use dawn to wash both sides. I love this printer - it is allowing me to take my patented product to market without injection molds, and at pretty high quality, speed and quantity. Being able to design a part and have it in 20 minutes to test is amazing. I print PLA tough (I hope it comes back???) and PLA, but have also printed a lot of ASA. Thanks for your good advice.
VoxelPLA claims their filament is tougher than normal PLA, and you use the PLA Tough settings to print it.
Per their website:
Bambu Lab X1 Carbon / P1P:
Bambu Lab X1 Carbon / P1P Bambu Studio Profile
For Bambu Lab X1 Carbon / P1P, you can use the Bambu PLA Tough pre-set in the slicer. No need to make any changes.
Might want to contact them and see if they can tell you how the two filaments compare in mechanical strength..
Can I use Isopropyl 99.1% to clean it of course when it’s cool down.
IPA will dissolve and dilute oils on the plate, leaving you with an oil/alcohol solution on the plate. IF you thoroughly remove that solution, wiping with a clean towel turned on every wipe, or rinsing with large quantities of fresh IPA, you might get the plate clean before the alcohol evaporates and leaves the oil behind, but spread around the plate. I use IPA if I know I’ve accidentally touched just one spot on the plate, and but I only clean that one spot to avoid contaminating the rest of the plate.
Dish detergent actually removes the oils. The detergent molecules actually attract and encapsulate oil molecules, holding them in suspension so that they are easily washed away completely by running water. Using detergent and water is just more certain than IPA to be effective.
In Australia we can’t buy Dawn.
Before buying my X1C, my Ender had a stock PEI plate that I cleaned with Iso. (Ours only comes in 100%). I tried cleaning it with dish soap as recommended by BL, but after that, bedplate adhesion was gone. Nothing stuck without glue and even attempts at recalibration failed, so I reverted to my iso. Right now I’m printing again with no adhesion problems. I guess I will need to find out if iso has any lasting negative affect on my BL textured plate
Dawn is not the only effective cleaner. Personally, I avoid anything labelled “soap” because most soaps can include animal and vegetable fats and oils which will prevent filament adhesion. You want a dish detergent known for its ability to dissolve and carry off grease and oil. Avoid anything that claims to be gentle on hands, or that contains skin moisturizers.
It might help to compare the ingredients in locally available detergents with the ingredients in Dawn. Note that Dawn uses multiple solvents and surfactants, including denatured alcohol and even a small amount of lye.
Finally got around to trying Simple Green / Mean Green.
Spray the plate or pour some on a wash rag. I went full strength for the test, but you can probably dilute it. Wash it using a rag like you would with Dawn.
Be sure to rinse with hot water. There was a difference in the feel of the plate between this and Dawn when done. Had no problems with prints sticking, but did have to remove the plate and let it cool a little more before removing parts. And if the plate and part cool to room temperature, it almost slides off, like it does when using Dawn.
BL tech support ok’d the use of this as a cleaner. I checked with them before testing.
I am looking into using the dishwasher. Did you use dishwasher tablets when cleaning the plates? Or just the dishwasher with no cleaning agent? Thank you in advance!
BL recommended using soap. You just don’t want anything the will leave a coating. Spotless finish soaps and additives coat the plate to make the water run off, so those are out.
One of the best cleaners is plain old cheap, dry, dishwasher powder. if you want to see how effective it is, put some in a stained coffee pot or cup, add really hot water and let it sit. Will remove most, if not all of the staining. If any is left it wipes off easily with a paper towel. Because of the oils left behind by the melted plastic, I’d go this route.
@Quietman
Has anyone else had issues with their build plates rusting due to IPA use?
So, I used 90% and 70% IPA up until a week or so ago. I never had any failed prints because of it, but my PEI textured plates did start rusting, which started leaving rust spots on the bottoms of my prints. But now that I know the alcohol breaks down the plate, it makes sense why it could eventually rust. I just never would have thought that would be the case.
I’ve never seen that happen and I have over 3K hours on my textured PEI plate. I always heard IPA was ok but not to use acetone.
I’ve never seen rust on my plates. I’d assume rust coming thru would mean the coating has failed and you need a new plate or to do something drastic
