H2D Poor Print Quality
What should be the k for the Filament then in your opinion ?
well, I did everything the support told me to do… such as validating / tightening / re-seating screws, heaters and nozzles, swapping out all items mentioned… might be the extruder / toolhead. however, support didn’t suggest anything towards that direction. I followed all recommendations such as the plenty wiki articles and all steps involved, uploaded almost 1tb of data and still… I would not run the calibration again since I had these ugly results…
Hello,
I am new to the Forum. I am running a Service Providing Print Farm. My FDM experience is around 12 years now and I was an employee of Stratasys for several years. So I would say I am experienced FDM user.
Running in addition SLS, SLA and MJF Printers on factory level and 2 High Temp Printers for PEEK and ULTEM.
I am currently owner of around 15 BambuLab Printers. Several A1 Mini, X1C, P1S and a new H2D.
I am printing with the H2D since appx. 1 month now and printed several third party materials and also BambuLab Materials. PLA, PETG, ASA, PPA CF, PPS CF, PA6, HIPS, PCTG etc.
I have my standard Material in the right nozzle and using the left only for support generation.
No multicolor printing for me on this printer.
Example: I print BambuLab ASA with BambuLab Profiles. At a random point of Layers 20+ I get stringing, ghosting and some kind of layershift + bubbles. Bottom part of the print is fine and look good.
I first thought it is a thermal problem but everything I tried is not working out at all.
Similar problem. I recalibrated all and started new prints to see if the problem is gone.
I don“t think that there is a Z-Axis problem.
All the Materials i use, I also use on my P1S and X1C and they work perfectly.
Printing with a support material like HIPS is even not possible and ends in a desaster as once the nozzle changes I get small holes in the outside walls of the printing material. I tried also PETG with PLA supp, vice versa and the official support Material from Bambu. Quality not satisfying.
Even with the matte PLA from Extrudr PLA NX2 the print quality compared to my X1C and P1S printers is not really satisfying.
I am actually a huge Bambu Fanboy and got rid of 10 Prusa Printers, considered to add 3-5 more H2D“s by this year to my fleet but with the current print quality there is a big question mark.
Would be glad if somebody could help me out, probably you faced a similar problem.
Thanks
Normal values for pla and a 0.4mm nozzle are between 0.015-0.025 depending on speed.
Support just got back to me regarding my issues; here is what they are suggesting to check:
I have definitely seen this happening to others I wonder if they will do a ā€œrecallā€ on the extruder gears sometime so a somewhat lifetime warranty
Are you sure? I checked my Values in Bambu Studio and I also have 0.033 for Bambu Basic PLA.
I guess it varies from differen filament colors. My purple is 0.026 (measured by auto calibration) and most of my other bambu pla is 0.033. All dried.
Today morning i received the same Email - after i varified that this isnt the case, i got an answer like this:
Hello,
May I ask if you confirm that the metal gear and plastic gear are properly attached together? I recommend referring to the wiki to check.
If the metal gear is wobbling or loose, this could be due to the extruder gear. If not, I will again reach out to the R&D department and ask for further instructions.
Please feel free to contact us if you have any further questions.
I answered that i am sure - now we will see…
dont think so - my dried PLA is going 0.030 and a bit more
Hallöchen, ich habe gerade mal wieder ein Video von Schwaighoferart (top 3D Druck-Kanal) angeschaut. Es kann für viele eine Lösung für gewisse Druckerprobleme mit dem H2D geben, schaut es euch mal an. Ich habe keine, da ich es genau so von Anfang an gemacht habe.
is this video in english or could you maybe explain it ?
He suggests to perform a factory reset and then a full calibration afterwards (with the high temperature bed leveling enabled).
no offense, didn’t improve anything on my end but might be good for others to try
I tried the factory reset and calibrations. The whole shebang. No improvements. Support is now going to send me a new printer. Fingers crossed I am blessed and I too can have nice prints out of the box. Thanks for everyone who provided suggestions and guidance here.
Ich denke aber, dass einige Fehler beim Drucken auch auf Grund des schlechten bzw. unsachgemäßen Transports des H2D verursacht wurden.
Da kann ich der deutschen DHL ein dickes Lob aussprechen. Mein Drucker war vorbildlich verpackt (sogar extra mit Schutzfolie), ohne den kleinsten Kratzer.
I think a lot of my symptoms might be explained by backlash in the extruder somewhere: extreme stringing, bad small hole dimensional accuracy and generally bad print quality. Too bad I already requested refund. I’ve spent enough time debugging a brand new 3000$ printer.
My problems were a very pronounced Z-banding and blobs and bubbles within the layers, especially with large prints. This was particularly noticeable, for example, with the AMS stacker that I printed to stack my AMS.
I did and checked the following:
  1. Extruder checked → loose nozzle and extruder
    Gear → negative, everything was OK
  2. belt tensioned → one screw was relatively loose.
  3. manual leveling of the heating bed
  4. complete calibration of the printer as mentioned with a hot heating bed
All these steps have now resulted in the printer delivering significantly better results.
I think that Bambu will certainly improve one or two things here with firmware.
@WisestMoose Hi, I saw your images and I seem to have the same identical problem. trying to attach images to show you but think limited as I’m a new user. But almost identical under-extrusion, holes and distortion on the Benchy roof that you got, especially on the hull and Benchy archway/roof. I set up the printer last night, dried the Bambu PLA Silk+ for 12 hours, then this morning ran first test using the built-in Benchy in the H2D itself. So… my initial first impression is …UGGGHHH!!!
Checked packaging and no obvious signs of damage, dropping or anything… so … now waiting for support as well.
