https://makerworld.com/en/makerlab
With more to come…
With more to come…
Maybe we should start with this
Can anyone upload a template? I can’t find the option.
Start with “Create from blank”. Then you got the option to use a template.
has anyone worked out how to make a light box yet lol
Thankyou Great tool!
Nice tool, but I can’t figure out how to get bold font?
Just a suggestion:
You are able to export the designed stuff as a *.json
It would be nice if you are designing a model wich features the MMS, that you are able to share the exportet template, so other users can start from there.
But you are not able to reimport the json file into MMS (or I didn’t find it) and you are also not able to attach/upload the *.json to your model.
I cannot get my sign to download… just crashed the open tab. its super annoying! I can download the STL but the the 3mf
Hi, I am unable to download my designs it just greys out and freezes. If tried multiple devices and pc, it does the same thing. I have noticed if I delete all SVG’s then it will download. Help…
The Make My Sign App is no longer adding the holes. It shows in tan instead of black and when you download in 3mf or stl there is no hole there,
Unable to print male lab my signs. Tried using 3 different browsers. When I hit download 3mf or stl, the download hangs for ever… Also, cannot print previously created files… When I drag to bambu studio, they don’t appear on the build plate… Disappointing…
Is there any kind of an update or fix for this. I download my stl and when loaded into Bambuslicer(or any other slicer) the rendering is all out of whack.
And yes I verified same units of measure.
Bummer, having the same issue here. The tool worked for me a month or so ago to make a few desk plates. Came back today to make a couple new ones and nope. 3mf export does not work. (Produces a file with nothing in it.) STL export works but creates a massive STL file that has the base plate sort of next to the text instead of embedded in it. Have attempted to create a plate with multiple browsers, all with the same result. Please fix this tool!
I submitted a help ticket and haven’t received a response yet.
Sign maker. Have the same problem, screen grays out and can not down load any files.
