P1s calibration for 0.2 nozzle
Hi all,
I seem to be having a bit of an issue today with calibration of filament with 0.2 nozzle. When I try to run the calibration on my P1s I get error message;
“Your nozzle diameter in preset is not consistent with memorized nozzle diameter. Did you change your nozzle lately?
nozzle in preset: 0.2 Stainless Steel
nozzle memorized: 0.4 Stainless Steel”
Now on the Prepare page I have the 0.2 nozzle under printer. I can’t for the life of me get the calibration to work! I can get it to work if I set the nozzle to 0.4 with the 0.2 nozzle physically installed; however, the results suck!
Any help would be greatly appreciated! I’m positive it’s a stupid simple solution, I just can’t find it in google or wikis.
I am not sure if the steps are the same for the P1, but for the X1C, on the printer, go to Settings->maintenance
Then on the right, select stainless steel nozzle and 0.2 size
You can change the nozzle size on the P1S in the “Accessories” setting.
Picture from here
Thanks for the info, it has been corrected! The issue I guess was upgrading to the newer control panel, which doesn’t have the option to swap the nozzles.
