P2S: Extruder Overload
I downgraded the firmware, but unfortunately the issue still persists. It appears that the extruder filament sensor may be faulty.
Hey! I had the “extrusion motor is overloaded” error too! On my P2S! After successfully snapping the connector to the board on the (the small one by the filament sensor , and replacing for £25) (Don’t be like me and just unscrew the filament sensor from the extruder and wiggle it out!, good learning curve though), I actually got to totally dismantling the extruder, at first- (I did it three times!) The big orange gear had some, 5-8 specs of filament dust on- got it off with ISO and cotton buds- thought ‘great! Fixed’ Na, no-no. Life isn’t so simple - so I took it apart this time completely (others were just the cog) , and inspected all the little gears, screws and spring- be careful to keep a good eye on these small extruder mechanisms, they are EASY to lose! Well anyway I simply just reassembled- and now its working perfectly again!!
Yes, I ran through the nozzle, PTFE tube, AMS checklist first, but nope- nothing seemed to work until I simply disassembled and reassembled the extruder in full. I’d ran for only 150 hours of print time before this error showed its face.
Point being to my OP in this thread is that it was never that ‘my extruder was overloaded’ it appears the spring was out of line in the extruder from out of the factory- what else can I think with only 150 hours of print time?
If you wanna try and fix it this way look for P2S: The complete teardown on Youtube and look at around 17 minutes in and he shows how the little gears sit together- simple when you have the picture infront of you. Good luck!
Thank you for the tips. I’ve already disassembled the extruder twice. The issue is that when the extruder error appears, I turn off the printer, and a few hours later it works again and prints for about an hour before the error comes back.
They’ve sent me a new extruder filament sensor, which I’ll replace to see if it resolves the issue. If not, I’ll have to return the printer and stick with my A1, which has been printing reliably without any problems.
I think that in some cases it has to be a software issue. When I get the error on one of my machines, I wait a few minutes and click to continue and it’ll either show the message again (so I wait a bit longer), or it’ll go on to complete the print. My other P2S is constantly complaining about the nozzle being clogged, when in fact it isn’t. I carry out regular maintenance and can’t see any issues with either of them. Otherwise, when they’re not reporting errors, they print great.
Filament sensor replaced, but the issue still persists. I’m now waiting for the buffer replacement. Printing from the external spool works fine. :neutral_face:
When you took the extruder apart did you break it down completely or just the orange cog and gear? Right after I sent my last message I actually got the error one last time, but that was because I had a cable weighing down on the PTFE tube at the rear, thankfully! (and have a spare set of extruder gears now if I need them in the future)
I disassembled the printer “head” as requested by the seller to provide photos.
Given that printing from the external spool works without issues, what could be the likely cause?
I got error HMS_0300_0900_0002_0001 (extruder overload) on my P2S and I did many research about this problem on how to repair it. I dissembled the extruder (everything was fine here), did cool pull (everything was clean). My problem was when the printer was purging colors did that error 4 times and later begin a chickling noises. before all this, I was doing some test and calibration using PETG and after swicth with PLA the problem arise. I noticed that my AMS was slithly different to unload and load filament and I begin to check all my setting and I found that my Max Volumetric Speed was super high compared with I have before, So I placed back to the way It was. Bump! problem disappeared and the AMS is working normal now. I Recommend you check your Max Volumetric Speed before doing anything else, because this setting control how the extruder works with the filament. I hope this help somebody as it worked for me.
Hello, I am yet to unbox my P2S, but judging from this discussion I am beginning to have some concerns and wether or not I should just send it back immediately. I have not got the AMS unit or the filament buffer, so (as I have read) there shouldn’t be any issues over there, and I will use the PTFE tubes included. The prospect of having to completely break apart and look at every mini-scule part of the printer is daunting. Given I do not have the extas, is it likely that this won’t be a problem (I read all manuals and watch reviews and read procedures for all products I buy, the bambu lab P2S is no exception)?
Same issue here, “Not extruding normally”, and sometimes “Extruder overloaded” when i press “resume, problem was fixed”
At the moment i cannot finish 1 print.
In my case, i do have to say it actually was not extruding filament and thats why it stopped.
The printer stopped extruding, it noticed this, moved to poopchute, recovered itself, and started printing again.
It did this 2x, then i manually stopped the print as i have gaps.
This whole thing usualy happens on layer 1 or 2.
Today, restarted the print without the option “automated calibration flow” and with the door open, been going for 1 hour in my 3 hour print.
It feels to me as there is no filament debris in nozzle or extruder gears as each print will always start decently, i would assume if there is an issue like this that it would not even start the print.
Thanks for the tip. In my case, when I try to load the filament directly on the printer, it can’t complete the process. It pushes the filament to the head, the sensor detects it, but it pushes too hard and trips the buffer at the back.
I was previously able to do small prints (60 min max), but now the filament can’t be loaded from the AMS.
Having the same issue… tried to print the vented poop shoot as my first print. Did fine for 8 hours, then got the extruder more overload error.
Lots of clicking noises
Multiple cleans, cold pulls, and extrusions, (nozzle was clean) we got it to print for 30 more min then the error happened again.
No fixing it this second time… had to cancel the print.
Super frustrating… brand new PS2, brand new black basic PLA, in a brand new AMS 2 pro.
This is our first Bambu, and so far we are not impressed.
Did you check if the problem persist using different filament (Pla, Pla+, Petg or Asa) also using different filament settings like bambu or generic? Did you dissemble the extruder and everything looks ok? Did you check the cutter blade is correctly installed? Did you perform restore to factory settings?
Is this specifically related to the 01.01.00.00 (20251014) update? Do you think this issue can be fixed in the software?
Because many people say the problem persists even after cleaning, and three people I know have returned the device. Dozens of people on forums and YouTube are also dissatisfied and want to return the device.
Has Bambu Official made any statement?
We ran through all the diagnostics on the QR error codes and help forums we could find. Nothing wrong with anything internal.
We tried to print the scraper handle and it couldn’t even put down the base layer properly. Did some more hot end/nozzle cleaning and cold pulls as we were suspecting heat creep.
With the door left open, the next print failed at about 70%. We then left the door open and took off the top glass and the next print made it to 80%.
Eventually, we took off the top glass, opened the door and ran a fan to blow across the top of the unit and a 6.5 print was successful.
Really disappointing performance from Bambu, especially since this is their filament.
I can’t add any good info yet. First overload for me. 0.4 HF. 32 volumetric flow. Actually printing 0.08 layers on quiet (50%), so no way it is flow related. Printed low and slow since this was a multiday print and was going to be away from home anyways. Afraid to restart until I get home and can do some checks to hopefully be able to finish the model. (Gift for someone). Edit. About 200 hours on the printer. Sunlu Pla.
NoH, just curious here. What kind of filament are you using? PLA? Max volumetric speed for PLA is usually around 12 to 17mm/s. Another question is why your nozzle is 40c when printing, when PLA is around 190 to 220c? And finally your chamber is pretty cold.
I didn’t noticed you put Sunlu PLA at the end. :joy:
