P2S: Extruder Overload
I seems that P2S is completely unprepared for .2 printing. Calibration sucks. With A1m I can go back and forth between .2 and .4 nozzles but it seems that P2S needs to be re-calibrated every time and even then .2 printing is terrible.
I came here to commiserate and pile on. I got my P2S delivered yesterday (USA), and I’ve already had two issues that make me grumpy after the amount of money I spent for a supposedly near-idiot-proof version. I’m writing up my experience in case others come across this post.
Issue 1: Nozzle clumping detection calibration failed
The P2S calibrated itself during the first bootup with no errors. After updating the firmware and re-running the calibration, I kept getting an error that the nozzle clumping detection calibration failed. The fix was to tighten the left-hand bolt on the metal nozzle wiping pad at the back of the hot plate.
Issue 2: Nozzle clog and extruder overload.
I printed 3 parts and then let the printer sit overnight. The last 2 prints were using Bambu’s PETG HF. Upon first trying to use the printer in the morning with the same PETG HF filament, I got an error that the printer had abnormal filament resistance. After running a few procedures to try to clear the nozzle, I restarted the print, and then I got the extruder overload error that is the topic of this thread. After removing the nozzle to ensure it was seated properly and then retrying the print, I still got the same error. The issue was not with the extruder, but it was because the filament had hardened in the upper part of the nozzle, and the extruder couldn’t push more filament through it. I had to perform the drastic nozzle-clearing instructions for a P1S, which involves heating up an allen wrench, stuffing it into the feeder end of the nozzle, letting it cool, then pulling out the wrench and hopefully the stuck filament still attached. I then put the nozzle back into the print head and heated up the nozzle to 250 deg C to purge the remaining filament in the bottom part of the nozzle. I’m now able to print again, but I’m worried about what happens when I stop printing and let the printer sit overnight. I hope I don’t have to perform a cold pull every day to clear out the filament.
I also found a YouTube video where the European user, Benson Chik, had multiple clogs within the first week of use using the Bambu 0.4mm nozzle. He purchased an aftermarket nozzle for the H2D (they supposedly share the same nozzle), and he hasn’t had an issue in the last 3 weeks.
Good luck to you all. I hope Bambu is able to apply a longer-term fix.
Some of you may have a legit extruder issue, but I wanted to share my experience just in case the extruder was not the actual issue. I’m still bummed I had to spend over an hour researching and fixing the issue when the printer was not even 24 hours out of the box.
I’m new to this 3d printing world and ran into this problem last night. The print failed twice on the first layer in the same place causing this fault code. To me my problem looked like the bed wasn’t level in one area as the filament seemed to get squashed out. I ran the full calibration and so far so good. I guess time will tell. I hope this will help someone but please bare in mind I’m only two weeks into this printing game so know next to nothing :laughing:
Today my P2S had his first extruder overload.
This occurred during a start, after pausing a print.
When feeding by hand via the display, it feeds as intended, nozzle is not clogged, filament is extruded normally.
When the printer starts up again after the pause, it flushes, but suddenly feeds so fast, that the extruder skips and triggers the false clogged nozzle hms…
One thing I would suggest is making sure all of your PTFE tubing is still ‘good’ and that there are no pieces of filament left inside them, especially if you reused the same tubing from a previous printer on the P2S.
If you are under any doubt as to whether or not the tubing is ‘good’ I would suggest bypassing the tubing altogether whilst you diagnose/test and run it from the external spool. This just removes the tubing as a possible variable.
Doing this certainly increased the possible maximum volumetric flow testing for me from around 40mm3 to much, much higher. I believe that there are a few things that are possibly at play here.
  1. The P2S seems to have a really hard time with tubing at certain angles, which is very odd given it’s marketing around how much better the motor for extrusion was going to be.
  2. When we first got our P2S, many of us (?) required a firmware update to stop the ‘motor overload error’. I am still on the fence as to whether or not this fixed anything or just simply moved the goalpost so that the printer didn’t throw an error until the motor is strained even more… e.g if it required a force of x to be detected, don’t error until a force of x+5 is detected.
I was just getting this error trying to print PET CF and I unplugged the AMS to pull the top lid and that fixed it and it started printing.
this is why the p1s is #rocksolid compared to the p2s🤣
After some tinkering and a very unhelpful support Interaction I could locate the problem.
I calibrate my filaments, therefore I mean getting up to ~60mm^3/s with HF nozzle.
The purging speed after restart of a paused print is correlating with the max volumetric speed in the filament settings.
With this set to 60mm^3/s printing works just fine, it’s just the purging at restart that pushes the extruder to its limits.
From bambus side there is now way to set the parameters for that. They suggest sticking with 40mm^3/s…
I hade the same problem, when I changed from a short PTFE tube to the long one included in the package, the problem disappear. The PTFE I mean is the one between the filament buffer and the P2S.
I’ve been printing on my P2S for the last couple of months, and have done a lot of 0.2 work. This issue has only happened to me since the last update to Bambu Studio, although I don’t think it would cause this. I press resume without any intervention and it resumes the print flawlessly. Not sure if a software issue?
They write with Firmware version 01.01.01… but in the EU we only have version 01.01.00.21. So I assume that in China they have already released another version for testing. That is why it is not possible to download it within the EU.
Adding my experience. I’ve had my p2s for a week and had 10+ “extruder motor overload” errors. I’ve been using the 0.2 nozzle mainly, but I’ve got the error once or twice using the 0.4 nozzle as well. I can print for about 2 hours, then it errors again.
Might be coincidence, but it seems to consistently clog when printing Sunlu PLA+ Black filament. I thought the filament profile/temp might be incorrect. So I played around with it a bit, but didn’t seem to make a difference. I never had to manually create/modify filament profiles on my P1S, so maybe I’m missing something here.
I successfully did a manual Flow Dynamics Calibration, but didn’t seem to have an impact. I tired to do a manual Flow Rate calibration, but I can’t even get it to finish as I get to Calibration 2 and it errors out again.
Really annoying…my P1S was plug and print. My P2S has been the complete opposite experience.
I’m going to order some 3rd party 0.2 nozzles to see if that makes a difference.
Is the actual message “extruder overload” people are getting? I was getting constant errors saying there is too much tension in the extruder, until I had further hardware failures. Is this the same issue?
Update, mine has been getting worse since I last posted. I did have an actual blockage as one stage, and had to disassemble the extruder to remove the stuck filament. Since then it has been happening more and more. I still feel it’s a software issue.
Check out my post here. See if yours is affected also.
You have to take the extruder apart then remove the PCB on the filament sensor.
I will take a look later. I had issues with grey PLA (which I have been using for a while), but had no issues with 2 other colours. I believe that device is the Eddy sensor?
I think the problem may have simply been down to my roll of filament was not seated in the AMS correctly. I am using a new roll of grey PLA and no issues. The other cause was a bad roll of PLA but will try this again to be sure.
The issue with the overload on my P2S seems to be right at the nozzle entrance. When you remove the small filament/blade guide cover (one screw) you can see its possible for the filament to hit the rim of the nozzle in the Y axis, the cover helps guide the filament in X axis, but there is too much slop in the Y axis. I’ll wait and see if it happens a again and confirm, but it looks like it needs a mechanical fix.
I’m experiencing the same issue. The printer worked fine for about two weeks, and then the extruder errors started. I suspect it might be related to a recent firmware update, but I’m not certain. When a print fails with the extruder error and I select the option indicating the issue is resolved, the filament unloads and reloads. I can see the filament reaching the print head, but the printer doesn’t detect it, and the buffer at the back trips.
When the error occurs, I can turn off the printer, let it cool down, and then restart it without touching anything. After selecting that the issue has been resolved, the printer is able to continue printing.
I downgraded the firmware and no more problems for me
