Rough looking top layer
I’m using default settings and have gotten great top layers previously but all prints are coming out now with a rough looking top layer.
1st print - fantastic, nice top layer, clean letters
2nd print (wolves) - rough top layer, harder to read letters
Any ideas?
So far I have tried the following
Did flow dynamics and flow rate
Upped the top layer to 4 instead of 3 (made it worse)
Dropped the top layer speed (about the same)
Cleaned nozzle
Looking for any suggestions…
A bunch of people have noticed this. There’s some discussion in this thread. Not sure if the cause has been identified yet.
Have you left the Filament outside ? between the prints or while printing
Dry the filament.
The auto flow calibrations are unreliable so manual suggest if the drying dose not help . But flow/K calibrations needs to be done on a dry filament ( i guess this is P1 so only manual) I use Orca slicer better calibration options
There a quite a few discussions for perfect top layer and good top layer
  • More top layers gives better finish usually , but if it makes it worse that means - Wet filament , incorrect flow or K( dynamic flow) issues , more rare temperature or ambient temperature issue guessing PLA
  • But lately a new problem has been experienced including myself - after firmware upgrade factory reset and machine calibration is required ( do not ask me why but it solved quite a few issues )
These prints were done an hour apart from each other so I don’t think there should be an issue with the filament? I could be wrong though. Filament has been dried.
I will try the factory reset and post results as soon as I can.
EDIT
Factory reset worked WONDERS!!! To need to adjust anything.
Tune flow. not dynamic flow. The Flow Rate. There is too much plastic and the nozzle is carving rows in the top.
@Cleric happy to here that factory reset worked , wondering what Bambu changed a lot of people reported same problems and factory reset worked . I think they need to update the firmware update procedure :smiling_face_with_tear:
