Skew compensation in the Bambu X1C Firmware
See this post for a method of compensating in Firmware for Skew in the X/Y geometry of the Bambu X1C:
https://www.reddit.com/r/BambuLab/comments/1adh0bn/comment/kwp3rh3
See also this post in the Bambu Lab X1 Specific G-Code section.
WOW!! This is excellent. Great find.
I love that my X1C doesnt need constant calibration like any of my other printers but you can still run into the odd wee thing when you are printing precise stuff.
Thanks for posting. Is there anything similar to compensate for XZ and YZ skew? You can measure it using the CaliLantern or similar.
I think you just need to make sure, that your bed is perfectly level
Add this to the Bambu Lab X1 Specific G-Code thread.
@JonRaymond Thanks for your suggestion.
I’ve done that here
@Nebur I thought the same and I’ve included the suggestion here
I think this is actually something Bambu should have included in the official Wiki.
Presumably, this procedure will need to be repeated if the firmware is updated or factory settings are restored?
@lkraus I think the skew compensation factor will be saved to EEPROM along with other printer settings and as in Marlin I would hope that re-flashing the firmware will not change the contents of EEPROM.
Has anybody tried this yet?
M1005 [In]
M1005 can also be used with the [In] parameter to apply a skew correction factor (in radians)* for the XY axes. The correction factor can be calculated from 3 measurements of a test print as follows:
Y
^     B-------C
|  A-------D
+-------------->X
XY skew factor
Measure AC, BD and AD
Calculate AB and the skew factor:
AB = SQRT(2*AC^2+2*BD^2-4*AD^2)/2
skew_factor = TAN(PI/2-ACOS((AC^2-AB^2-AD^2)/(2*AB*AD))) radians
Apply the -ve of the skew factor as the correction factor with M1005:
M1005 I-skew_factor
Save the correction factor to EEPROM with M500
This is not iterative like M1005 [Xn] [Yn]. If you run M1005 [In] again the previous correction factor will be overwritten.
If you want to revert to the machine’s uncorrected skew use 0 as the correction factor for the [I] parameter:
M1005 I0
M500
*(if you want to check what the angle in radians is in degrees, multiply by 180 and divide by pi)
Bambu Lab’s M1005 [In] behaves the same as Marlin’s M852 [In]. Unfortunately they don’t (yet) seem to have extended this to correct skew in the XZ and YZ planes (like Marlin’s M852 [Jn] and [Kn] parameters do). At least I haven’t had any success trying M1005 [Jn] or [Kn] on firmware version 01.07.02.00
The M1005 gcode looks like a wrapper round (some of) the function of Marlin’s M852 with the addition of the [Xn] and [Yn] parameters as a convenient way for the user to enter just 2 measurements from a test print without having to calculate the skew factor. In the instructions pdf (link) from Bambu tech support they say they intend to improve the skew compensation method in the future. I hope they include XZ and YZ compensation.
It’s frustrating to have such a good printer but with closed source firmware. It’s the only thing I don’t like about the Bambu X1C.
@Nebur, I’ve now confirmed that M1005 [In] has the same function as Marlin’s M852 [In]
See my recent post in this thread for details.
@SimEyeSee Yes, I significantly reduced the skew in my XY axes with it.
@NeverDie Unfortunately they don’t seem to have implemented XZ and YZ skew compensation yet. See my recent post in this thread, titled M1005 [In], for details.
I will have to try it one day.
I did try this, no joy at all. ran 4 times and 4 measurements all the same values. printer is X1C and latest firmware.
It really works after I use it.
Solved the skew problem
But when I turn the power off and on again, it returns to the previous situation.
I did add the M500 command
@Giovanny Yes, I have the same result. M500 does not retain the setting when the printer is powered off…
In the instruction pdf for the M1005 gcode from Bambu tech support they say:
‘Add M500 save to the next line, so that the compensation value is still present after restart.’
But I just had my X1C powered off to fix a jammed extruder and the compensation value was lost.
as a ‘fix’ for this you could use the M1005 [In] format of the command and leave it as a permanent addition to your start gcode
please paste the gcode you used here
