Successful Prints
Model: Printables
Printed with Duramic PLA+ white. Printed way too fast for such a small model. Printed at 0.08mm layer height using the standard 0.4mm nozzle. Took about 34.5 min for print.
I thought the wings were going to be fused, because I had it too hot (240C) because I’d been printing larger things fast all day. But after carefully cutting away the brim, and then using a steel ruler to press on the wings, then magic! It moved!
Honestly this is hella impressive. I did all the wrong things (too fast, too hot), and it still worked!
Benchy for scale :slight_smile:
This snake is sick! It looks like an Armadillo Lizard! What filament did you use for it?
Hi, I am just about to trial mine. Could you tell me what settings & nozzle you used and did you disconnect the AMS?? Cheers ( nice print by the way )
Printed from the AMS with the default settings provided through the rfid chip. Only changed infill to 25% in bambustudio. Ofcourse used the engineer plate (other side of the pla surface)
Hi mate, thanks for replying. Did you notice any debris in the path through the AMS? Also was glue required for the Engineer Plate?? Cheers
No debris whatsoever. I havent use a gluestick on either pc, cf or pla.
Remember that you cf needs to be dry. I used mine till 8h after opening the spool and then dried again.
Printer: X1 Carbon with AMS
Filament: Prusament PC
Model Link: 3MF file for Bambu Filament Drying Cover | Bambu Lab Wiki
Print Settings: 0.4 mm Nozzle, Engineering Plate, Bambu PC settings*, 0.28 mm Extra Draft
Print Time: 4 hr
*I used the Bambu PC filament settings for the Prusament PC filament and it worked great!
Hi everyone, where can I find already colored projects?
Not sure if that is the right question. The gcode that controls the printer instructs which ams “port” to use and that code gets generated by the slicer. Ready to go colored 3d files by my knowledge are not usable because they are just the 3D objects. You need to do the coloring in the slicer software to generate the right code for the right printer.
Starting to figure out this printer and 3d printing. These are printed with the 0.2 nozzle with .1mm layer height. Eryone mat pla pretty much all stock settings, other than the supports that I had to play with quite a bit to get to work. About 2 hours each to print on the Carbon x-1.
Always looking to improve and am open to suggestions.
All prints done on X1 Carbon which was purchased in late December No prior 3d printing experience.
Articulated Dragon - 3D Printable Articulated Dragon by McGybeer
Filament - https://www.amazon.com/gp/product/B09YT2P9ZV/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Baby Yoda - Baby Yoda - Free Sample by MarVin_Miniatures - Thingiverse
Filament Body - https://www.amazon.com/gp/product/B08N4K8RS6/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Skin - 1.75mm 2KG-spool Greenery - Color of the Year 2017 FilaCube 3D Printer
Filament Nails - https://www.amazon.com/gp/product/B074DSD46L/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Wood Barrel - Barrel - Sea Of Thieves by bugman_140 - Thingiverse
Filament - https://www.amazon.com/gp/product/B08LGJFFSD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Vase - (Vase Mode) 3D Printable Inversion Vase by Clockspring
Planters Pots - Succulent Planter 11 by cgpena - Thingiverse
Darker wood - https://www.amazon.com/gp/product/B088BRY1PN/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Lighter Wood - https://www.amazon.com/gp/product/B074DSD46L/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Rustic Bowl - 3D Printable Rustic Bowl by Clockspring
Filament 1 - https://www.amazon.com/gp/product/B08LGN2Z3Z/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Filament 2 - https://www.amazon.com/gp/product/B08LGJFFSD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Butterfly - 3d STL Models for CNC Router Butterfly - Etsy
Gecko - 3D Printable Rustic Bowl by Clockspring
Filament - https://www.amazon.com/gp/product/B09XQ999KG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Bearded Dragon - Bearded Dragon Digital .STL File for 3dprinting Articulated - Etsy
Testing a few holes.
Model taken from Thingiverse.
:heart:
Printer X1C
Filament Polymaker Black ASA - Polymaker Bronze (it’s really copper)
Model link CarnyRex Creations
Print settings .2 on the stocks and .14 on the silk parts.
Print Time - all parts about a day and a half. about two to three hrs of assembly.
**Printer X1C
**Filament Polymaker Bronze, Jayo black silk, and Polymaker Matte OD Green
**Print settings Silks at .14 and Matte at .2
Print time 2 full days and half day assembly
I have more failed prints with the P1P than any other printer I’ve used. For anything complex or small, or sometimes even to large, it just goes too fast by default and screws itself up. I love getting a spaghetti monster 6 hours into a print because the nozzle was moving at mach 10 and raked across some infill that was curling up and knocked the model loose.
Wrong Thread my friend !
Printed on Bambu lab x1c with bone with pla from 3DE filaments
This is Clockspring 3D’s “624 Radical Flask”, printed on the Bambu X1-Carbon. The filaments are Amolen (red-orange), Locyfens (purple/black), and unbranded gold and black - all PLA. Generic PLA profile. This was a 43-hour print, but it took over three days because the printer paused overnight twice - the first was that the purple spool got stuck somehow, easily freed, the second was that the printer detected that the “poop chute” was full. Both times I corrected the problem and resumed the print.
Overall, a gorgeous print. Small bits of stringing on the outside, more on the inside (the lid screws on) due to overhangs, but it didn’t seem to create a problem.
Nope and not without picture . I stop spaming that thread . Maybe some of the @admins will erase that :wink: !
