The wait ends on March 25! 🚀
You can’t engrave plastic with Diode laser. just melt it :slight_smile:
The hand tuned benchy on the x1c and p1s require you to put it in ludicrous mode
This is why I stopped caring about benchy speed test. Like they’re specialized/customized to go as fast, as how do they really represent real world usage/performance.
:blush: Thank you! That I did not know. :blush: :blush: :blush:
What do you use instead? How do you judge it?
With modern machines, the speed of them isn’t as much of a factor like it use to be. I value quality print over speed, and my settings are typically tuned that way. In the past, pre-bambu and klipper, things were much slower so it was a bigger factor in things compared to now days.
I use to mainly print benchy’s to see where the quality level was at with a given machine. If I was tuning things, upgrading, modding, etc. Benchy’s all day. These days, I just don’t feel that same need.
When I got my X1C originally, I printed a full R/C truck on it. I put the peddle to the metal and never looked back.
So, for me, the benchy speed test doesn’t tell me what I want/need to know. It seems more like pointless flexing to me. Although this is me and my use case. I can still see the value others would find.
I guess in some way it’s like saying the little FWD version of a car is totally awesome because the AWD highly tuned race version placed well in it’s races. they’re the same car, but not the same. I’ve seen a ford escort that can tear it up, but I’ve also seen a ford escort that can barely get up to speed, so.
[edit] wait, I guess that didn’t actually answer the question. I don’t know, I just throw stuff at the machine now days and see how it goes. with the H2D, I’m going to feed it prints that traditionally had issues on the X1/P1 printers. From the reviews, it looks like some of the mechanically caused printing issues have been improved.
Look at Minute 10:00-10:01 at Boba Fetts chin…?!?
That´s not what i expect of a 2500€ Printer.
An the YTuber says nothing about it. …Shame on U guy…shame
If you watch the timelapse you can see the tree support for the chin failed. The reviewer didn’t mention this as this isn’t really related to the printer hardware.
Ahhh…nice answer.
The new flagship is not able to print this silly dust catcher an it´s okay ?
And why does he talk about the surface of the chest ?
That´s not Hardware of the printer !
I am sorry but this argument is weak.
Any model that has support fail will print poorly. The fact that supports can fail is just what happens in 3d printing. It doesn’t need to be addressed.
It seems you are hyper focusing in on a detail that isn’t really an issue. That being said, if this “quality flaw” is a deal breaker for you then don’t buy the printer? There are PLENTY of other options.
Hi Jon,
short answer.
I don´t like this kind of advertisement. It´s paid by BL.
It´s to early for me to make a buying decision.
Maybe on Black Friday :wink:
bye…
You’re shifting the goal post here. First you were all bent out of shape about a printing defect, now it’s because you don’t like being advertised to? Advertising is the whole point of hyping up a release date. If the printer/company isn’t for you, that’s 100% okay.
Failures don’t need to be addressed?!
That’s a bizarre attitude, given that a major part of engineering development is addressing failures.
You’re painting my statement with too broad of a brush.
Support failures don’t need to be addressed in this particular instance.
If a successful print requires supports, then why not?
I’m assuming maybe @JonRaymond means there are a lot of support parameters that could be tweaked that would make it work? Branching factors, limb thicknes, interface depth,… it’s a long list. I’m still learning what is what, in part because the in-line documentation is a bit telegraphic. Maybe meant to remind more than teach.
Support actually should be one of the strongest points of this printer, while you will be able to print support separately with the other nozzle.
Avoiding material contamination and other problems that may occur while printing different materials through the same nozzle.
And supports can be pretty important for a print. It even might make the difference between finishing or failing (with a printer full of “spaghetti”) a print.
But I believe that specific print was just printed in one material (not looked it back).
And like all printers, there might be a lot of factors that could cause errors. It could be the filament, bad slicing or bad airflow etc. So it posible should not be addressed directly to the printer to be honest.
The tree that was supposed to support his chin (and probabl eye slit in helmet) disappeared part-way through the time-lapse.
Screenshot 2025-03-26 133127
Screenshot 2025-03-26 133620
Screenshot 2025-03-26 133646
Maybe the toolhead knocked it over? Or it had poor bed adhesion? A thicker tree trunk and thicker tree limbs would be worth trying to give it more strength. You could also paint on more support for his chin to recruit more trees to support that area.
Bad Adhesion because of the poor quality bed heater they use potentially
Simply because the video is centered around the initial review of the printer not about how to print that particular model. If support failed on a bunch of other models, yes this would be more important to address as it would be a broader problem.
If you need a theory of what happened, my guess is that there was some fingerprints on the bed which caused the little tree support to detach mid print and lead to the overhang problem. Another theory is that the door was open for the camera time lapse and the air movement in the room cooled the front tree support and popped it off of the bed.
