Tpu 85a - helpppppp!
I also don’t now where to set retraction speeds - is this in Edit Filament - or in Slicer or at machine?
I dried overnight - now making settings to filament and slicer per stuff i found on the nets. And will give this a 4th try.
As stated, I have no clue how previous Eng printed with external spool - bowden tube. Hopefully if my settings work, I will try again with this setup.
You got this. After starting on 85a, you’ll be a pro after this
Yeah we will look into buying the TPU Feed module. Already purchased the HF TPU nozzle. what perplexes me most - again - the previous Eng printed fine. This leads me to believe he made additional changes - temps/speeds. As stated the file was corrupt and he had already left the compnay.
Broad speed and acceleration adjustments can be made on the display at any time. Usually, I just set speeds and accel’s in the slicer though.
As for the display looks, it is more a case of the Bambu wiki not keeping up with Firmware updates and me not being aware previously as to your printer :joy:
This is what it looks like now (without the green boxes and numbers, “silent” and so on are under Speed):
Regarding the changing of settings, it is very easy to loose oversight across the myriad of settings. So linking cause and effect can quickly spiral out of control.
It is usually best to try to dial in one after another starting with nozzle temp (although I never needed to do that with Bambu Filament), calibrating flow and flow dynamics for that and then, depending on print performance, look at retract settings and max flow (if needed).
I did dabble in fan settings in the past. It led me to train my dog to bite me whenever I even think about opening up a test matrix for that… :joy:
It is usually easier to slow down until the quality desired is reached. If high volumes are needed, get Quality first, then try to speed up.
PS: I took the pic from the H2C user manual. Here’s the link to the H2D manual just in case it may come in useful. https://csm.bblcdn.com/hub/4668d0ca43994ff3bff4b37f1a65c2e7.pdf
no
Besides your interface looks different from mine - how do you set speeds to 50%?
I can get to this screen on the machine - but when I set it to 50% it says setting speeds in idle mode does nothing. The 50% doesn't take.
When I go to print - select a file and go to start - there is no way to set the print speed. Is this set within the slicer and written in gcode.
I just responded to your response above about setting speeds in silent mode.
When I do this at the printer - it says setting this in idle mode has no effect. But when I go to print there is no option to set to silent mode - am I missing something?
You can do it multiple way. In the filament settings of the slicer , you can change max flow rate, you can also play with individual speeds in the speeds section of the slicer but I would just change the max flow rate though. on the printers screen itself, you can choose between 4 presets(one being the original speed).
I would suggest getting to know the slicer better. Maybe watch some YouTube videos. You’re trying to solve a puzzle blindfolded.
Update:
I made all the changes recommended on the website I posted above. Slowed down the first layer/infill - etc. Boosted temps a bit. Rewrote file and started the print - one line this time and a failure with resistance.
The Filament is being directly fed into head 2 - no bowden tube. I pulled a lot of slack and I can say there was no resistance on the filament. WTH man. I can’t get even one-two lines before failure.
Printing TPU85A is vodou.
Ah. I usually just set the speeds I want in the slicer. So it has been a while since I used it. When I did, I navigated to the control settings on the display and could operate it trouble free. It is also available on the Device screen in Studio when the print is running.
Update 2:
All settings the same from Update 1 - but I did set the speeds to Silent Mode. I didn’t realize - but you need to start the Print and then go to screen and set the speeds.
One line and failure.
I think that at this stage, it is really important to show pic’s or a video of the failure to help to narrow down the failure.
From your description, it could be a number of things (nozzle or extruder clogging? Common during troubleshooting…), but they are only really obvious when seeing/hearing the print…
Update 3:
  • Dried TPU over night
  • Settings from document I shared above - slowed everything down - reduce Max Volumetric Speeds - A bit higher temps
  • I switched out the 0.6 TPU HF with the 0.4 TPU HF
  • Material direct fed into Head 2 - plenty of slack with the inlet filament feed.
  • This is the farthest I have gotten to date using the supposed best methods for feeding + implementing the TPU HF nozzles.
  • Failure - but again got farther with the 0.4 than 0.6.
EDIT: I even slowed the Printer Down to Silent Mode. So super slooooowwwww.
This is the partial print I achieved on Normal Hardened 0.4 (not HF) - spool outside - filament run through Bowden tube. No high resistance warnings - it just stopped printing layers since the nozzle got clogged. No special settings - just setting material to Bambu TPU85A.
I showed some pics below of the print. I didn’t manage to take pics of my setup.
Top cover off - material direct fed into Head two - extruded a ton of TPU using tools on Machine - material moved fine - absolutely no tension in material.
Of all the settings I tweaked - buying the HF TPU Nozzle - at least mimicking the setup shown by Bambu - and absolute failure everytime
Again so weird the previous Engineer had issues - but at least managed to print without even worrying about nozzles or settings. It sucks his file was corrupt I could at least provide details of his settings. Maybe he found the magic sauce.
Mesh - that is why I’m here. I also consulted others online. I got settings directly from Filament Supplier. Sure, it’s hard to poke around the settings - not so intuitive. But unless I’m missing that one setting - nothing has worked. In fact, I wish I can set the material and just run the print. Hopefully Bambu would already have the correct settings applied.
Someone posted here they had success printing TPU with no changes to the settings. I tried this and a bunch more without success.
You are using 3rd party TPU correct? Shouldn’t your filament supplier should be the one providing the optimal profile?
In a business setting leaning on your suppliers should be your goto. If they don’t support you, you need to change to a supplier that does.
Dont run it trough Bowden unless you have a tpu assist module.
Glad youre here too.
I was just talking about tutorials like this. Gives you a quick breakdown of features and settings. So youre not fishing in the dark. May end up saving you time navigating the software
So I set the Printer to Bambu TPU85A in reality it’s Ninjatek Ninjaflex TPU.
This is from their website:
NinjaFlex TPU Print Settings
Recommended NinjaFlex TPU settings:
  • Extruder temperature: 225 °C – 250 °C (NinjaTek guidelines)
  • Bed temperature: 20 °C – 50 °C (room temp to 50 °C)
  • Print speed: 10–20 mm/s for top/bottom layers, 15–35 mm/s for infill/shell (depending on printer)
  • Infill/shell speeds: 15–35 mm/s for most setups
  • Fan: Use cooling fan for layers 2+ if available
Extra tips for smooth feeding and quality:
  • Dry the filament before printing — NinjaFlex absorbs moisture from the air, causing rough, weak, or stringy prints. Dry at 50–60 °C for 6–12 hours, then keep sealed
  • Use a low-tension roller feeder to reduce drag on the soft filament
  • Avoid Bowden extruders if possible; direct drive or short PTFE tube in the extruder is better
  • Load manually to prevent filament damage; jog extruder until you just see the color, then stop
  • Bed adhesion: If no heated bed, use glue or blue painter’s tape
  • Flow calibration: Turn off auto-calibration; use manual flow calibration
  • Avoid overloading nozzle temps — for soft 85A TPU, 250 °C can help with low back pressure
Why these settings work:
NinjaFlex is a flexible TPU with ~85A Shore hardness, requiring higher nozzle temps for smooth extrusion and lower bed temps to avoid warping. The moderate print speeds help prevent stringing and ensure good layer adhesion.
If you’re using a specific slicer (e.g., Bambu Studio, OrcaSlicer, PrusaSlicer), you can import a NinjaFlex TPU profile to set these defaults automatically
