Sure, it’s not secret.
I got inspired here by the post of Umuzoo Warped bed :( seems like a common QC issue - #251 by Umuzoo
I got a glass plate cut at the local glass workshop, dimensions 256x256mm, for 2 EUR. I didn’t want to fillet the edges because I could do it at home with Dremel tool, but they usually can fillet the edges of glass if the customer wants it.
I bought a sheet of magnetic sticker 1mm thick. I found it at local store with promotional materials, I’m sure it can be found on the Internet as well, just search for “magnetic self-sticking sheet”. Dimensions of my sheet were 600x400mm, so I got enough material for two applications for 6 EUR.
I simply applied the sticker to the glass and then I used sanitary silicone (clear, transparent, chemically neutral) to fasten the glass on the heatbed. One drop at each of front corners (front = door side), one drop at the center. After few hours, when the silicone cured, it’s dead stable. It sits on the edges of the heatbed, becaus it is warped upwards, and it’s supported in the center, so it doesn’t bend up/down.
Original steel sheet goes to very top of this and is held down by magnetic force of the sheet.
I tried to heat the bed up to 110 degrees for 2 hours, there’s no visible degradation.
I tried to print different materials - PLA, PETG, PA, ASA. It was almost flawless, only with ASA and veeeery long object (200mm long), the forces in ASA were so high that it actually lifted steel sheet from the magnetic bed, but I suspect it would do the same with original bed.
Placing the steel sheet at the assembly is a bit tricky since those aligning brackets are no longer available, they are too low. I’m going to design and print some extensions.
Dave
