Z Banding in P1S, nothing fixes it
Hello guys.
So I’ve had this problem for a couples of days and I don’t know what else to do. I have tried everything and nothing fixs it.
I have two BambuLab P1S with AMS. I use the same PLA filament in both of them. Same brand, same color, same everything. So, one of them (the right one in the picture below) is having this artifacts that I think it’s called Z Banding, but I’m not sure. The other one is giving me awesome results, partially.
To the left, machine nº1 producing excelent walls. To the right, machine nº2 with Z Banding.
The same prints, but from the side.
The pattern is only visible in tall print like this bookend support. I know it is a tall and thin print, but it has been printing great since the very beginning. It’s now that I’m having problems with the vertical artifacts in machine nº2. I did nothing, it just appeared.
The thing is, I though one reason might be a badly calibrated PLA, so I calibrated it using machine nº2 and this is the result:
To the left, machine nº1. with overextrusion. To the right, machine nº2 with perfect extrusion.
So, I have this absurd situation:
  • Machine nº1: no Z Banding, but overextrusion with calibrated filament.
    • With the default BambuLab PLA Basic profile I have the same exact results, but without overextrusion.
  • Machine nº2: Z Banding, but perfect extrusion with calibrated filament.
    • With the default BambuLab PLA Basic profile I have the same exact results, but with underextrusion.
Printing settings in Bambu Studio, the same in both machines:
  • Outer wall: 200 mm/s
  • Inner wall: 300 mm/s
  • Infill: 250 mm/s
  • Acceleration: as default: 10.000, 500, 5.000, 0, 2.000 and 100%.
  • This values have given me excelent results, until now.
I have also made a VFA test with this result:
Machine nº1, with BambuLab PLA Basic default profile
Machine nº2, with BambuLab PLA Basic default profile
I have tried everything in machine nº2 in order to fix this problem:
  • Clean the X-axis carbon rods with IPA
  • Greasing Z-Axis Lead Screws
  • Cleaning and lubbing Y-axis and Z-Axis Linear Rods and Bearings
  • Changing the extruder with a new one.
  • Lubbed idler pulley
  • Tensioned the belt following the official steps Belt tensioning procedure | Bambu Lab Wiki and also centering the belts.
Nothing fixes this problem. Nothing, and I don’t know what else to do.
Do you have any idea? Thanks in advance :slight_smile:
Here are a couple of links from the net and the forum
5 Ways How to Fix Z Banding/Ribbing - Ender 3 & More - 3D Printerly
[Z Banding / Z Wobble: How to Prevent It | All3DP](https://all3dp.com/2/3d-printer-z-banding/
Is that a problem ? micro-z-banding - Bambu Lab X1 Series / General discussions - Bambu Lab Community Forum
Quality problems on walls (Z-Banding?) - Bambu Lab X1 Series / Troubleshooting - Bambu Lab Community Forum
For those with z-banding problems - Bambu Lab X1 Series / Troubleshooting - Bambu Lab Community Forum
Thanks, I have already checked them but nothing fixes this problem :confused:
I noticed in one ( i have not read it properly ) something about a bent bar/rail , perhaps tech support can help if you get in touch and supply a log file
Update: I tried to print slowly, like half the speed. No effect. Looks like something mechanical
Did you do the vibration compensation calibration after retensioning the belts?
Just a wild guess: one pulley is imperfect or something sticks to one of these pulleys
I have had a similar issue, no fix for it here are some images
Nop, nothing wrong down there
I have finally sent a ticket in order to see if it’s covered by warranty. Will see, but this is frustrating
Have you swapped the hotends over ?
The nozzle can wear out and with that the calibration goes down the drain.
Probably not the case but since you have two machine and a check only takes a few minutes…
As for those moving belts…
It does not matter if they move a bit on those pulleys.
But if the belt gets stuck on the top/bottom of the pulley it can create vibrations and uneven results.
The print however would not come out with fully even defects like yours, it would be more random.
I suspect a combination of problem sources here that work together to give you these headaches.
Hello! @JoseDextro It’s been a while but… Did you solve it? I’m facing the same issue now :frowning:
Is the wall the right height or shorter than it should be? I would definitely be looking at the bottom movement. Perhaps belt is too loose causing slippage? No idea.
In my case, I’ve tested all the things, belts, screws, motors… etc.
Nothing works :frowning:
Did you file a support ticket?
Did you ever get a solution for your z banding? One of my printers started doing the same thing.
I’m experiencing the same issue I’m going to try replacing my extruder
Hi! Did you manage to fix this issue? I am having the same one now, with banding almost diagonal.
I have done maintenance to the pulleys, rods, belts, nothing seems to make a difference.
I even tried to downgrade the firmware and changing the slicer.
Any suggestion appreciated!
I fixed it!!! If you have as many hours on your printer as I do (5600+) things get loose I was instructed to loosen the 6 screws that attach the plate to the z rods and then wiggle it and tighten them back down and by god it worked!
Yup, when I had my P1S, I faced the same issue as the heatbed got loose. But I noticed it sooner on it literally banging against the chute wall.
