I took some time looking in to this and it looks like the problem is caused by the code-signing of the application. The 3Dconnexion drivers is a third party library that needs to be loaded and BambuStudio doesn’t seem to have the correct entitlement set.
This is the reason why it does work in OrcaSlicer; OrcaSlicer is not signed. I checked the code in both BambuStudio and the OrcaSlicer fork and the code for the SpaceMouse is identical. So it should work for BambuStudio too, if OsX would allow it to load those third party libraries.
I tried removing the code-signing from BambuStudio but unfortunatly this leaves an app that can’t be started. Does anyone know of an unofficial, unsigned build for OsX?
Looks like it might work if you build it yourself from GitHub, see this issue.
It would be great if Bambu Lab would fix this is the next release, I’m guessing that a large number of customers will not be able to compile their own software for the printer.
Working on PC version of BS for me, however I don’t see any configuration options. Is there a way to bring up a config/settings section? I know in PrusaSlicer there was some weird keyboard combination you had to press to get the settings pop-up window to come up.
Normally if you open the 3Dconnexion Utility (lower right taskbar) and click BS it will allow you to change settings for that particular program. Use the “Advanced Settings”. The issue I find is that BS doesn’t seem to use these settings?
In BS I find the Spacemouse support really quite slow to rotate compared to the click and drag with a mouse. I’ve max out the speed setting in the 3dconnexion utility but it doesn’t have much effect. Also more annoyingly for some reason I can only zoom via push and pull rather than up and down as I prefer. Changing the settings in the utility also doesn’t fix it.
Has anyone else experienced this? I’ve used a SpaceNavigator for well over a decade and I find this behaviour very odd and a little frustrating.
Exactly the same as I have experienced. The Advanced settings in the 3Dconnexion app don’t seem to have any effect on how the SpaceMouse Wireless works in the Bambu Studio app. Which is why I was wondering if the BS app worked like PrusaSlicer where there was a keyboard shortcut to bring up a “secret” menu to control the SpaceMouse settings that was inaccessible any other way in the app.
Found it, Ctrl-M as in the PrusaSlicer app worked in Bambu Studio to bring up the 3Dconnexion settings menu. From there you can adjust the speeds and fix the performance of the SpaceMouse in BS.
I was having the same problem with Orca Slicer. I opened the 3D connection home app in the dock of my Mac. I selected “properties”. Under configure I clicked on the up/down arrow and selected “add application” Then I selected Orca Slicer. Now it works.
I’m on windows 11, space mouse works but up and down are sooooo slow. I couldn’t find any “properties” to add application on 3d connexion app, almost giving up om bs and space mouse. Any help? Btw. weird same behavior on both orca and bs but works fine on prusa slicer.
