I print a lot of things but anything wide or large has bad warping. Sometimes I can solve this with lots of glue and a large brim… i tried pei plate, glacier and frostbite but for this print nothing is working. Any ideas how to fix the warping on the edge.
Having this issue on my h2d and my x2d
This piece isnt that large, only 5”x4”x1”. I tried brim and didnt work, this specific instance i put lots of
Glue on glacier plate.
Even though it’s called glue, its main purpose in this case isn’t to make the filament stick better, but to act as a release layer so the print comes off more easily. Don’t let the word “glue” throw you off. You need to know exactly when, how and where to use it.
Especially when you say you’re using a lot of glue, that’s definitely a problem, regardless of the application.
It’s important to combine several different measures here.
First, check whether the glue might actually be causing the problem rather than solving it. We’d need to know exactly which type you’re using to assess that.
Then there’s the infill, which is one of the most important factors. Depending on the infill pattern, the material can shrink differently.
On top of that, you haven’t used a brim.
There’s no single magic fix here. It’s about looking at several factors and addressing them together.
I’d strongly recommend taking a look at this Wiki:
And I genuinely mean this in a friendly and helpful way: Take some time to learn about when and how to use each build plate, including reading the manufacturer’s recommendations. The same goes for glue, as I mentioned earlier.
And then there’s the fact that your printer’s (plural) seems to be having problems all the time? Looking at your topic history, I have to wonder: has they ever actually worked properly?
In addition to the resources already mentioned, there’s lots of general & design-level warp mitigation solutions and information in this post:
Personally, if a brim or mouse ears aren’t enough to reliably hold the print down, it’s usually back to the design for me. Even with glue as adhesive (eg. on Engineering plate), a bad warp may lift the plate instead (which can be hard to notice). And I don’t like glue anyway.
