After unboxing and getting everything setup after receiving my X1C today, I entered my WiFi info and the Bambu happily connected to the wifi & downloaded the latest firmware.
Afterwards, it reports the error: HMS_0500_0200_0002_0001: Failed to connect internet, please check the network connection.
I am unable to connect either through Handy or Bambu Studio. A network test on the X1C reports a <20ms ping to the internet, so clearly it can and is connected.
Same for me. The “test network” on the printer is working. No problem with the network. But I got the same error "Failed to connect to the internet, please check your network connection. [0500 0200 0002 0005 1743 09]” about two days.
Just unpacked a new X1C… same experience … Could connect to my Wifi at work… could download firmware… but when went to use the system, got the message “failed to connect to Internet” and so no cloud based services available… Wonder if it is a firewall port issue. Anyone know if certain ports need to be open?
Same issue here. Connected, downloaded new firmware, and now the printer itself says it is online and it passes a network test, yet it doesn’t show up in bambu studio, handy, and I can’t connect to it by ftp. I can ping the printer without issue.
I’m a fairly smart guy when it comes to networking, and I can’t think of any options I haven’t tried yet to get it to work.
So I tried the printer on multiple access points and bambu studio on multiple computers each with the same results. However, I did get a working connection when I put the printer on a separate network on a wifi hotspot, and it worked via cloud and lan only. I also had a successful connection connecting to the windows 10 hotspot feature.
I’m wondering now if the common demonator for me was the use of openwrt routers. I’d imagine a good chunk of 3d printer coneseuers have custom firmware and configuration for their wifi as well.
Other people with issues, what kind of routers are you using?
I just received my X1C yesterday and was running in to the same issue.
I was able to fix it by going in my router config, for the 2.4GHz wireless settings, and disabled ‘20/40 MHz Coexistence’. Everything now connects!
Might be something to try.
My router sets up a 2.4Ghz and a 5GHz wlan using wlan steering using the same ssid. My brand new X1-Carbon did not connect to the 2.4GHz wlan as long as both wlans were active. I had to inactivate the 5GHz wlan and only then the printer made a successful connection. After the initial connection worked, I reactivate the 5 GHZ wlan again and now after powering on the printer it always connects successfully to the 2.4GHz wlan. Obviously the printer firmware cannot handle wlan steering on the initial wlan connection.
