Hi there,
I have a new P1S with AMS set up since saturday. It’s my first BambuLab, but I have a few years of printer-experience with other models.
Since yesterday evening, nothing is sticking to the bed properly anymore. I was able to get one simple print to stick with a raft, but only then. I mainly use aftermarket filament (Elegoo, material4print), but the supplied BambuLab PLA doesn’t work either. The pre-sliced files from the SD card fail as well. I use the default textured PEI plate; and of course I also have that set in the BambuStudio ![]()
Sometimes the print comes off very fast, sometimes it takes a while and dislocates mid-print, leading to spaghetti.
One time, the purge-line dislocated and sticked to the nozzle, getting dragged into the print (see image)
The last print that worked flawless was a drybox for the AMS; small footprint (so prone to dislocate) and lots of fine walls, but worked as expected (Elegoo PLA). I started that print yesterday before work; when I got home, the issues began.
Things I tried:
- washing the build plate with hot, soapy water
- washing the build plate with 99% Isopropanol
- leaving the door open
- keeping the door closed
- removing the top glass and leave the door open
- using a large brim
- using OrcaSlicer instead of BambuStudio
- raising the bed temp 5°
- raising the bed temp 10°
- bed leveling enabled before every print
- at some point the nozzle clogged as well, I usued the needle, removed with an allen key and then did a cold-pull (like described in the wiki)
- I dried the filament
It’s not that I never had a dislocated print before, but usually that was due to faulty bed-leveling on my end. Since I had a printer with a leveling sensor, I never had this happen, especially not with a textured plate (on other printers, of course)
I live in central europe, it’s not humid here, room sits around 35-40%, filament lives in the AMS at 28%. Room temperature is around 20°C. Right now the printer sits on a very stable dining table, usually it has its own place but its footprint is too small to do maintenance like placing the AMS somewhere else and reach every corner. I bought on of those pavement stones, but it’s still drying.
I’m a bit puzzled where to go and what to try from here. What are other troubleshooting methods I forgot about?
Best,
Lucas
