The Biqu plates definately work and grip well, and last many thousands of hours, but you need to check which filaments they are designed for, as the wrong combination can stick so hard the filament can pull the coating off the plate.
From my experience the standard pei plate works best and is consistent.
I picked up a BIQU pei plate thats similiar in colour/texture to the OEM plate and the centre part where the BIQU logo is failed within a hundred hours or less so I lobbed it straight in the bin.
I just use Bambu PEI plates for everything now and it’s perfect.
