I a 100% agree with user_4064251085. I have had exactly the same issues he has had. I use a mesh network that has a dedicated back haul and that’s capable of Wi-Fi 6. I’m pretty sure it’s not my network.
The load up time is not a big deal for me. My printer is pretty much running 24/7. So there’s not much turning it on and off. Though I will agree it does take probably like 30 seconds or so to load. And I’ve had it twice now lose the device. So it usually seems like after a restart of the machine all of a sudden the ex-touch can connect to it. So I have no idea what’s going on there.
Exactly everything else he has said has been an issue for me also.
I am not sure if this is sarcasm or not in an attempt to elicit a response. No. This would not be the case. If anything it would improve performance on older hardware.
I have many devices working with the 2.4 Ghz band. The mesh uses a dedicated 2.4 Ghz antenna specifically for running up to 50 devices on a single mesh hub in the 2.4 Ghz band. I have had several “high-end” routers, none of which have shined a light to the stability of the Velop mesh. It has been a godsend.
Also, user_4064251085 is having the exact same problem. So unless he also uses a Velop mesh network, then I doubt it is related. There are multiple people reporting these issues. Just look at the issues tab on the Github repo for the project.
ok then it might be that it does not like mesh. I have a basic home router in my garage and every single time I power up xtouch it connects to the printer under 10 seconds. and every single time it connects.
On another note. There appears to be a problem with SanDisk 32 GB micro SD cards not mounting with these displays. Mine wouldn’t, and there’s a couple of people on the ESP32 forum with the same issue, even though their 32gb sandisk is not the same classification as mine. Some people replied they’d had o problems, but didn’t give the model of their microSd
Hi, I tryied install Xtouch for my P1S. I have ESP32-2,8. It is connected to my local nework, found printer,but when I confirm it, then it is disconected and repeate to connect, search printer etc. I tried change SD card, USB cable, adjust Coldboot time, but not help. Does somebody have any idea what can I try?
Just sharing my experience as I’ve been using XTouch since it swapped to that name of P1 Touch. Ive have one installed on my P1P for awhile now and just installed one on my P1S. No issues with the printer. I had one connectivity issue installing the firmware with my computer on the 2nd one [doing everything I did exactly like the first one] yet the computer wouldnt find the COM port so I just used a different computer instead of messing around. Since installing XTouch I havent even touch my original screens. Sometimes I keep my printers on for days and never had disconnect issue. Only thing I’ve noticed is sometimes when I switch to move the X/Y gantry to the Z it sometimes wont swap it. Still works just on the wrong arrows, but thats usually when I’m going to fast on the screen or something. I’ve even connected the optional chamber temperature sensor to both with no issues. I have one that powers on with the unit via the USB port on the printer and one I power externally. This has greatly improved interfacing with the printer which was my initial concern with the original screen.
I recently noticed the other day (12.18.23) there was an OTA update pushed to the XTouch when I turned it on. Nothing seems to have changed, but thought I’d mention that if no one else noticed
Looks like a third party company is about to release a touchscreen with more capability than xtouch, plus the ability to control multiple printers. Skip to 6:13 in video. https://youtu.be/p5dx5MqJTAA?si=nyQFnLZJrGwPHVNY
@dupras.steve this looks great! may I ask how you routed the USB cable on the P1S? The riser / lid seem to be in the way, i see there is a hole over on the right side but wasn’t sure i wanted to run such a long cable
The cable is routed through the same hole as the power cable for the original screen. I had to slightly shave down the rubber surrounding the USB plug-in to fit it through, but it was not a problem.
I feel like using the mobile phone app is much more convenient and user friendly than any touchscreen… I barely use my P1S screen for anything other than checking how much print time is left
